Saltar al contenido principal
Dell Inspiron 13-7359 WLAN Adaptor Replacement
Qué necesitas
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: paso 1, imagen 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 2, imagen 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 3, imagen 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 4, imagen 1 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 4, imagen 2 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 4, imagen 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: paso 5, imagen 1 de 1
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 6, imagen 1 de 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: paso 7, imagen 1 de 1
    • Gently remove the WLAN adaptor.
Conclusión
Bo Yi Lim
Miembro Desde 04/02/19
205 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G4, Harley Spring 2019 Miembro de IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 166
