Saltar al contenido principal
Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement
Qué necesitas
  1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Battery: paso 1, imagen 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 2, imagen 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 3, imagen 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 4, imagen 1 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 4, imagen 2 de 3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 4, imagen 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 6, imagen 1 de 2 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 6, imagen 2 de 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, WLAN Adaptor: paso 7, imagen 1 de 1
    • Unhook both of the wires attached to the WLAN adaptor.
  8. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 8, imagen 1 de 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  9. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 9, imagen 1 de 1
    • Gently remove the WLAN adaptor.
  10. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, USB/SD Card Reader IO Circuit Board: paso 10, imagen 1 de 1
    • Using the plastic opening tool, unhook the black cable as shown.
  11. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 11, imagen 1 de 1
    • Gently pull to unplug the speaker cable.
  12. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 12, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the 3.9mm Phillips screw as shown.
  13. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: paso 13, imagen 1 de 1
    • Gently raise the USB/SD Card Reader IO Circuit Board and pull the part free from the device.
Conclusión
Bo Yi Lim
Miembro Desde 04/02/19
205 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G4, Harley Spring 2019 Miembro de IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 367
