Saltar al contenido principal
Dell Inspiron 13-7359 Speaker Replacement
Qué necesitas
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: paso 2, imagen 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13-7359 Speaker Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13-7359 Speaker Replacement: paso 3, imagen 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: paso 4, imagen 1 de 3 Dell Inspiron 13-7359 Speaker Replacement: paso 4, imagen 2 de 3 Dell Inspiron 13-7359 Speaker Replacement: paso 4, imagen 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Dell Inspiron 13-7359 Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: paso 6, imagen 1 de 2 Dell Inspiron 13-7359 Speaker Replacement: paso 6, imagen 2 de 2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: paso 7, imagen 1 de 2 Dell Inspiron 13-7359 Speaker Replacement: paso 7, imagen 2 de 2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Conclusión
Una persona más ha completado esta guía.
Katie Ragsdale
Miembro Desde 01/30/18
192 Reputación
1 Guía escrita
Equipo
Baylor, Team S1-G6, Johnson Spring 2018 Miembro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 350
