Saltar al contenido principal
Dell Inspiron 13-7359 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 13-7359 Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  4. Dell Inspiron 13-7359 Hard Drive Replacement: paso 4, imagen 1 de 2 Dell Inspiron 13-7359 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
Conclusión
6 personas más completaron esta guía.
Equipo
Baylor, Team S1-G6, Johnson Spring 2018 Miembro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 1,926
