Introducción
This guide provides step by step instructions to remove your Dell Inspiron 13- 7359 cooling fan. You will need a phillips head #0 screwdriver and a small plastic spudger.
Qué necesitas
Flip your device over so the back cover is facing you.
Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
Una persona más ha completado esta guía.
