Saltar al contenido principal
Introducción
This guide will show you how to replace your device's battery without any hiccups. You will need one Phillips #0 screwdriver and one plastic spudger.
Partes
No se especificaron partes.
  1. First flip over the laptop to expose the back panel
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. To remove the old battery, slightly lift the bottom edge of the battery with your hands Now slowly pull the battery towards you to fully detach the battery Now slowly pull the battery towards you to fully detach the battery
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Conclusión
3 personas más completaron esta guía.
Equipo
Baylor, Team S1-G6, Johnson Spring 2018 Miembro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,008
