Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If you notice your computer screen is damaged and needs to be replaced, this guide may be able to help. This guide will show you how to replace the display screen in a few steps.
  1. WARNING :  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer . After working inside your  computer, follow the instructions in After working inside your computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer . After working inside your computer, follow the instructions in After working inside your computer.
    • Close the display and turn the computer over
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
    • Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
  4. Before opening device, ensure that all data is backed up on a hard drive to prevent data loss. Loosen and then unplug the hard drive cable.
    • Before opening device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Remove 2 M2 3mm screws, using the Phillips 1 screwdriver. Remove the battery.
    • Remove 2 M2 3mm screws, using the Phillips 1 screwdriver.
    • Remove the battery.
  6. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM.
    • Pry open the clips and remove the RAM.
  7. Unplug the daughter board cable in two places marked in red, then remove it. Unplug the fan cable marked in orange. Unplug the fan cable marked in orange.
    • Unplug the daughter board cable in two places marked in red, then remove it.
    • Unplug the fan cable marked in orange.
  8. Remove 1 MR 3mm screw, using the Phillips 1 screwdriver, on the cooling fan. Remove 1 M2 2mm wafer screw, using the Phillips 1 screwdriver, on the cooling fan. Remove the cooling fan.
    • Remove 1 MR 3mm screw, using the Phillips 1 screwdriver, on the cooling fan.
    • Remove 1 M2 2mm wafer screw, using the Phillips 1 screwdriver, on the cooling fan.
    • Remove the cooling fan.
  9. Remove 3 M2 2mm screws, using the Phillips 0 screwdriver, on the heat sink. Remove the heat sink. Remove the heat sink.
    • Remove 3 M2 2mm screws, using the Phillips 0 screwdriver, on the heat sink.
    • Remove the heat sink.
  10. Remove the screws from the LCD cable bracket. Remove the LCD cable bracket. Remove the LCD cable bracket.
    • Remove the screws from the LCD cable bracket.
    • Remove the LCD cable bracket.
  11. Unplug the LCD cable. Unplug the touchscreen cable. Unplug the touchscreen cable.
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Unscrew 2 M2.5 7mm screws, using the Phillips 1 screwdriver, on the right screen hinge. Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge. Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge.
    • Unscrew 2 M2.5 7mm screws, using the Phillips 1 screwdriver, on the right screen hinge.
    • Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge.
  13. Carefully undo the tape Unplug the two black and white wire leads
    • Carefully undo the tape
    • Unplug the two black and white wire leads
  14. Carefully remove the tape that is attached to the screen by prying it off with your fingers. Remove the tape outlined in red. Adjust the screen so that the laptop is open flat against the surface.
    • Carefully remove the tape that is attached to the screen by prying it off with your fingers.
    • Remove the tape outlined in red.
    • Adjust the screen so that the laptop is open flat against the surface.
    • Remove the LCD display screen by pulling it gently away from the back.
Conclusión
Wow. Thank you so much. I will do this when I get my replacement screen.
Chris Gallego - Contestar
Finally tried this and noticed you left out the most difficult part which is the part of putting on the actually replacing the screen. This is only for removal of the screen. And the instructions are definitely not the same backwards. You left out the part with the cable/wires closing with the hinges being the most difficult part. I actually forced the cable too much stripped the cable that goes around the new screen. Have to order new cable now ugh
Chris Gallego -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 1,366
