Saltar al contenido principal
Dell Inspiron 13-7353 Palmrest Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: paso 1, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: paso 1, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: paso 1, imagen 3 de 3
    • Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
    • Detach and remove the Bottom Base Cover using an opening tool to pry it off.
  2. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 2, imagen 3 de 3
    • Unplug and gently pull the hard drive cable to loosen it.
    • Remove the 2 - M2 x 3mm screws.
    • Remove the Battery.
  3. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 3, imagen 3 de 3
    • Remove the 2 - M2 x 3mm hard drive screws.
    • Remove the Hard Drive.
  4. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 4, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 4, imagen 2 de 2
    • Unplug the speaker cable.
    • Remove the Speakers.
  5. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 5, imagen 2 de 2
    • Unplug the fan cable.
    • Unplug and remove the daughter board cable.
  6. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 6, imagen 3 de 3
    • Unplug the antenna cables.
    • Unplug the power button cable.
  7. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 7, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 7, imagen 2 de 2
    • Remove the 1 - M2 x 3mm screw.
    • Remove the USB / SD Card Circuit Board.
  8. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 8, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 8, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 8, imagen 3 de 3
    • Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
    • Remove the Cooling Fan.
  9. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 9, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 9, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 9, imagen 3 de 3
    • Loosen the screws.
    • Remove the Heatsink.
  10. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 10, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 10, imagen 2 de 2
    • Remove the 2 - M2 x 3mm bracket screws.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 11, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 11, imagen 2 de 2
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 12, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 12, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 12, imagen 3 de 3
    • Open the screen.
    • Loosen the LCD cable and peel it off of the base (highlighted with arrow).
    • Remove the 3 - M2.5 x 8mm hinge screws.
  13. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 13, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 13, imagen 2 de 2
    • Remove the screen assembly.
    • You may need to pull the hinges up.
  14. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 14, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 14, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 14, imagen 3 de 3
    • Unplug the cable.
    • Remove the DC Jack.
  15. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 15, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 15, imagen 2 de 2
    • Loosen the keyboard cable tape.
    • Loosen the keyboard cable latches.
    • Unplug the keyboard cable.
  16. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 16, imagen 1 de 1
    • Unplug the keyboard backlight cable.
    • Unplug the touchpad cable.
  17. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 17, imagen 1 de 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 17, imagen 2 de 2
    • Remove the 1 - M2 x 2mm Wafer screw.
    • Remove the Motherboard.
    • The piece remaining is the Palmrest Keyboard.
  18. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 18, imagen 1 de 1
    • You can further disassemble by removing the touchpad.
  19. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 19, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 19, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 19, imagen 3 de 3
    • Unscrew the 4 - 2x2mm wafer screws.
    • Peel back any tape holding the back plate on.
    • Lift and remove back plate.
  20. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 20, imagen 1 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 20, imagen 2 de 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: paso 20, imagen 3 de 3
    • Peel back under-button tape.
    • Remove touchpad.
    • You have now stripped the keyboard! It is ready to be replaced.
Conclusión
5 personas más completaron esta guía.
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 7,162
