Introducción
If you notice that your computer programs are slow and your computer is taking long to load any programs, this guide may be able to help. The motherboard is responsible for running your computer, and if it is damaged or too old, your computer's performance may not be optimal.
Herramientas
Partes
No se especificaron partes.
Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
Unplug the daughter board cable in two places marked in red, then remove it.
Unplug the fan cable marked in orange.
Remove 3 M2 2mm screws, using the Phillips 0 screwdriver, on the heat sink.
Remove the heat sink.
Remove 2 M2 3mm bracket screws, using the Phillips 1 screwdriver, on the LCD cable bracket.
Remove the LCD cable bracket.
Una persona más ha completado esta guía.
