Saltar al contenido principal
Dell Inspiron 13-7353 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 13-7353 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Unplug the hard drive cable from the motherboard.
  5. Dell Inspiron 13-7353 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #000 screwdriver, remove two 3mm screws from the hard drive frame.
  6. Dell Inspiron 13-7353 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Lift the hard drive up and out of the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 799
