Introducción
The hinges are what control the device lid opening and closing. If the hinges on your device are worn from general wear and tear or have been broken, refer to this guide for step by step instructions on how to replace the hinges.
Qué necesitas
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Remove the three 8mm screws with the Phillips #0 head connected to each of the hinges.
Take out the antenna cables from the routing guide on the hinge cover by pulling them from their original position
2 personas más completaron esta guía.
