Introducción
This guide will show you how to remove and replace the hard drive from a Dell Inspiron 13-7347.
Before you begin, power off the system and unplug all external devices and power sources including the AC adapter.
Before the laptop is opened, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface during the process to prevent electrostatic discharge (ESD).
Qué necesitas
Flip the device over, so that the back is facing up.
Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
Use the suction cup to lift off the back case.
Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
Lift the hard drive up and out of the device.
Una persona más ha completado esta guía.
