Saltar al contenido principal
Dell Inspiron 13-5368 Webcam Replacement
Qué necesitas
  1. Dell Inspiron 13-5368 Webcam Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 13-5368 Webcam Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Webcam Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: paso 2, imagen 2 de 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Webcam Replacement: paso 3, imagen 1 de 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Webcam Replacement: paso 4, imagen 1 de 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Webcam Replacement: paso 5, imagen 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: paso 5, imagen 2 de 2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Webcam Replacement, Screen Display: paso 6, imagen 1 de 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: paso 6, imagen 2 de 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: paso 6, imagen 3 de 3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Webcam Replacement: paso 7, imagen 1 de 1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Webcam Replacement: paso 8, imagen 1 de 1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Webcam Replacement: paso 9, imagen 1 de 1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Webcam Replacement: paso 10, imagen 1 de 1
    • Detach the display from the base.
  11. Dell Inspiron 13-5368 Webcam Replacement, Webcam: paso 11, imagen 1 de 1
    • Use your plastic opening tool to pry the LCD back cover from the display panel.
  12. Dell Inspiron 13-5368 Webcam Replacement: paso 12, imagen 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: paso 12, imagen 2 de 2
    • Carefully separate the back cover from the LCD screen.
    • Carefully remove the ribbon cable that holds the webcam to the screen, then unplug the webcam from the ribbon cable.
Conclusión
Matt Sugrim
Miembro Desde 09/27/17
1,042 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S14-G6, Boczar Fall 2017 Miembro de USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,241
