Introducción
This is a simple step-by-step guide on how to remove and replace a webcam for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This task requires a great amount of care because you are working with glass and will take approximately 15 minutes to complete.
Qué necesitas
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
Use your plastic opening tool to pry the LCD back cover from the display panel.
