Introducción
This is a simple step-by-step guide on how to remove and replace a touchpad for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. It is very easy to do and will take about 7 minutes.
Qué necesitas
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
Casi Terminas!
Conclusión
