Introducción
This is a simple step-by-step guide on how to remove and replace a battery for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. It is very easy to do and will only take about 5 minutes.
Qué necesitas
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 personas más completaron esta guía.
3 comentarios
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
I have this same question^. Can I reuse the cable from the old battery?
