Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se requieren partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
    • Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  3. Lift the hard-drive assembly off the system board.
    • Lift the hard-drive assembly off the system board.
  4. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Lift the hard-drive bracket away from the hard drive.
    • Lift the hard-drive bracket away from the hard drive.
  7. Place the NEW hard drive in the hard-drive bracket. Place the NEW hard drive in the hard-drive bracket.
    • Place the NEW hard drive in the hard-drive bracket.
  8. Replace the four screws that secure the hard-drive bracket to the hard drive.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  9. Place the hard-drive assembly on the system board.
    • Place the hard-drive assembly on the system board.
  10. Slide and connect the hard-drive assembly to the system board connector.
    • Slide and connect the hard-drive assembly to the system board connector.
  11. Replace the screw that secures the hard-drive assembly to the system board.
    • Replace the screw that secures the hard-drive assembly to the system board.
    • Turn over the system board assembly.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 6
Últimos 30 Días: 18
Todo El Tiempo: 125
