Saltar al contenido principal
Dell Inspiron 13 7378 Wi-Fi Card Replacement
Qué necesitas
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: paso 1, imagen 1 de 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 2 de 2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusión
Una persona más ha completado esta guía.
Equipo
Gateway, Team 1-3, Saknee Spring 2022 Miembro de Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 278
