Introducción
In this guide, we will show you how to remove and replace Memory Modules.
Partes
No se requieren partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the screw that secures the memory module cover to the computer base.
  2. Use a plastic scribe to lift the memory module cover up at an angle and ease the tabs out of the computer base.
    • Use a plastic scribe to lift the memory module cover up at an angle and ease the tabs out of the computer base.
  3. CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the memory module from the memory module connector. Remove the memory module from the memory module connector.
    • Remove the memory module from the memory module connector.
  6. Align the notch in the NEW memory module with the tab in the memory module connector.
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  7. Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  8. Align the tabs on the memory module cover with the slots on the computer base and snap the cover into place.
    • Align the tabs on the memory module cover with the slots on the computer base and snap the cover into place.
  9. Replace the screw that secures the memory module cover to the computer base.
    • Replace the screw that secures the memory module cover to the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 13
