Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
    • Remove the hard drive cable from the hard-drive system board connector.
  2. Lift the hard drive out of the hard drive compartment. Lift the hard drive out of the hard drive compartment.
    • Lift the hard drive out of the hard drive compartment.
  3. Detach the hard drive cable from the hard drive cable connector.
    • Detach the hard drive cable from the hard drive cable connector.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the hard drive from the rubber case.
    • Remove the hard drive from the rubber case.
  6. To replace the hard drive, replace the rubber case onto the hard drive.
    • To replace the hard drive, replace the rubber case onto the hard drive.
    • Attach the hard drive cable to the hard drive cable connector.
  7. Place the NEW hard drive in the hard drive compartment.
    • Place the NEW hard drive in the hard drive compartment.
  8. Attach the hard drive cable to the hard-drive system board connector.
    • Attach the hard drive cable to the hard-drive system board connector.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 90
