Saltar al contenido principal
Dell Inspiron 11z-1121 RAM Replacement
Qué necesitas
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 11z-1121 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: paso 2, imagen 1 de 2 Dell Inspiron 11z-1121 RAM Replacement, RAM: paso 2, imagen 2 de 2
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: paso 3, imagen 1 de 2 Dell Inspiron 11z-1121 RAM Replacement: paso 3, imagen 2 de 2
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
Conclusión
Equipo
USF Tampa, Team 1-5, Nance Fall 2016 Miembro de USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 475
