Saltar al contenido principal
Dell Inspiron 11z-1121 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: paso 2, imagen 1 de 2 Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: paso 2, imagen 2 de 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Hard Drive Replacement: paso 3, imagen 1 de 2 Dell Inspiron 11z-1121 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Hard Drive Replacement: paso 4, imagen 1 de 2 Dell Inspiron 11z-1121 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
    • To be safe, make sure you either wear an anti-static wrist band, or rub your hands against a metal object to remove any static.
Conclusión
2 personas más completaron esta guía.
Brandan Eng
Miembro Desde 10/04/16
143 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-5, Nance Fall 2016 Miembro de USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 1,983
