Saltar al contenido principal
Dell Inspiron 11z-1121 Fan Replacement
Qué necesitas
  1. Dell Inspiron 11z-1121 Fan Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Fan Replacement, Keyboard: paso 2, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement, Keyboard: paso 2, imagen 2 de 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Fan Replacement: paso 3, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement: paso 3, imagen 2 de 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Fan Replacement: paso 4, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Fan Replacement, Fan: paso 5, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement, Fan: paso 5, imagen 2 de 2
    • Start by prying the outer casing of the laptop using the plastic opening tool. Start from the bottom and work your way around the edges.
  6. Dell Inspiron 11z-1121 Fan Replacement: paso 6, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement: paso 6, imagen 2 de 2
    • Remove the outer casing to expose the motherboard.
    • Remove five .75 mm screws using a PH1 screwdriver.
    • Make sure to keep track of your screws.
  7. Dell Inspiron 11z-1121 Fan Replacement: paso 7, imagen 1 de 1
    • Remove wireless wide area network (WWAN) card by sliding it out of position.
    • Make sure the wires attached to the WWAN card are not detached when doing this step.
  8. Dell Inspiron 11z-1121 Fan Replacement: paso 8, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement: paso 8, imagen 2 de 2
    • Unscrew the two 0.9 mm screws that are holding down the screen.
    • Lift the screen up and towards yourself to detach the screen from the laptop.
  9. Dell Inspiron 11z-1121 Fan Replacement: paso 9, imagen 1 de 1
    • Lay the screen down and pry the left corner of the plastic casing that is located behind the screen.
  10. Dell Inspiron 11z-1121 Fan Replacement: paso 10, imagen 1 de 1
    • While holding screen, remove the motherboard by wiggling it around and pulling outwards.
    • In this step you are trying to pull the motherboard out from the VGA socket it is attached to in the back left corner of the laptop.
  11. Dell Inspiron 11z-1121 Fan Replacement: paso 11, imagen 1 de 2 Dell Inspiron 11z-1121 Fan Replacement: paso 11, imagen 2 de 2
    • Unscrew the two black 0.5 mm screws holding the fan in place.
    • Remove the fan by gently lifting the component upwards.
Conclusión
Cassidy Chen
Miembro Desde 10/04/16
289 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-5, Nance Fall 2016 Miembro de USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Miembros
5 Guías creadas
Un comentario
I see there are a few more screws on the bottom. Can't we just unscrew those and take off the bottom panel?
bluejedi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 1,008
