Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Memory Modules.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the battery release latches to the unlock position.
  2. Slide the battery out of the battery bay.
    • Slide the battery out of the battery bay.
  3. Slide the battery into the battery bay, until it clicks into place.
    • Slide the battery into the battery bay, until it clicks into place.
  4. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the memory-module cover off the computer base.
    • Lift the memory-module cover off the computer base.
  7. CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  8. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  9. CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory  module in the upper connector.
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  10. Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  11. Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  12. Tighten the screw that secures the memory-module cover to the computer base.
    • Tighten the screw that secures the memory-module cover to the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 21
