Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  4. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  7. Place the NEW hard drive in the hard-drive bracket.
    • Place the NEW hard drive in the hard-drive bracket.
  8. Replace the four screws that secure the hard-drive bracket to the hard drive.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  9. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  10. Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  11. Replace the two screws that secure the hard-drive assembly to the computer base.
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 47
