Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se requieren partes.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Disconnect the display cable from the system board connector.
    • Disconnect the display cable from the system board connector.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the two screws (one on each side) that secure the display assembly to the computer base.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  7. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Connect the display cable to the system board connector.
    • Connect the display cable to the system board connector.
  9. Route the Mini-Card antenna cables through the routing guides on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  10. Connect the Mini-Card antenna cables to the Mini-Card(s).
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 29
