Introducción
In this guide, we will show you how to remove the Display Assembly.
Partes
No se requieren partes.
  1. Follow the instructions in "Preparing to Work Inside the Computer." CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of  your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Follow the instructions in "Preparing to Work Inside the Computer."
    • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Close the display.
    • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
  2. Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
    • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the two M2.5 x 5-mm screws from each hinge bracket.
    • Remove the two M2.5 x 5-mm screws from each hinge bracket.
  5. Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  6. Lift the display assembly up and out of the computer base.
    • Lift the display assembly up and out of the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 4
Todo El Tiempo: 40
