Introducción
This guide will show you how to replace the WiFi module on your Dell Inspiron 11-3168. Note: There is one small screw that may be difficult to grip with your fingers. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Qué necesitas
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
To install the replacement module, start at step 4 and work your way backwards to step 1.
Una persona más ha completado esta guía.
