Saltar al contenido principal
Dell Inspiron 11-3164 Speaker Assembly Replacement
Qué necesitas
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: paso 1, imagen 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: paso 1, imagen 2 de 2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: paso 2, imagen 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: paso 2, imagen 2 de 2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: paso 3, imagen 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Conclusión
Equipo
USF Tampa, Team S6-G4, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 149
