Saltar al contenido principal
Dell Inspiron 11-3164 Screen Replacement
Qué necesitas
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: paso 1, imagen 1 de 2 Dell Inspiron 11-3164 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: paso 2, imagen 1 de 1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
Conclusión
Equipo
USF Tampa, Team S6-G4, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 165
