Saltar al contenido principal
Introducción
If your mousepad is working incorrectly, refer to this page's troubleshooting guide. This fix is only necessary after you have attempted the prerequisite fixes.
  1. Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws. With a metal spudger, remove the plastic cover to unveil the final screw.
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. With a metal spudger, pry apart the bottom cover working around the edges. While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. With the J1 screwdriver bit, unscrew  three (3) size 40 mm battery screws.
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  5. With tweezers, disconnect the battery cable.
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  6. With tweezers, disconnect the keyboard cable With tweezers, disconnect the touchpad cable. With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • With tweezers, disconnect the keyboard cable
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • Gently remove the mouse touchpad.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S6-G4, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 59
