Introducción
This guide will require one screwdriver with a Phillips bit from the approved iFixit toolkit.
Qué necesitas
Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 6 mm screws.
Remove the plastic cover to unveil the final screw holding the front and back frame together.
Remove this last screw of size 6mm with the J1 phillips head bit found in the approved iFixit toolkit.
Una persona más ha completado esta guía.
