Saltar al contenido principal
Dell Inspiron 11-3162 Palmrest Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Back Cover Removal: paso 1, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Back Cover Removal: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 3, imagen 1 de 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 4, imagen 1 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 4, imagen 2 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 4, imagen 3 de 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Battery: paso 5, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Battery: paso 5, imagen 2 de 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 6, imagen 3 de 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Wireless WLAN Card: paso 7, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Wireless WLAN Card: paso 7, imagen 2 de 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 8, imagen 2 de 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 9, imagen 1 de 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Use the tweezers to unplug the DC Jack.
  11. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 11, imagen 1 de 1
    • Use the tweezers unplug the Speaker Cable.
  12. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 12, imagen 1 de 1
    • Use the tweezers to remove the CMOS Cable.
  13. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 13, imagen 1 de 1
    • Use the tweezers to remove the Touchpad Cable.
  14. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 14, imagen 1 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 14, imagen 2 de 3 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 14, imagen 3 de 3
    • Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
  15. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 15, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 15, imagen 2 de 2
    • Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
  16. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 16, imagen 1 de 2 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 16, imagen 2 de 2
    • Remove the keyboard cable.
  17. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: paso 17, imagen 1 de 1
    • Remove the motherboard by gently lifting upwards from the edges.
  18. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Palmrest Keyboard: paso 18, imagen 1 de 1
    • Gently grip and pull the speaker to remove it.
    • Now you've removed the Palmrest keyboard!
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 957
