Introducción
This will show you how to remove & replace your motherboard. This would be a last step in attempting to repair your computer if you've attempted the other guides.
Qué necesitas
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
5 personas más completaron esta guía.
