Introducción
In this guide, we will be showing you how to remove and replace the Memory Modules.
Partes
No se requieren partes.
  1. WARNING:  Before working inside your  computer, read the safety information  that shipped with your computer and follow the steps in  "Before Working Inside Your Computer" After working inside your computer, follow the  instructions in "After Working Inside Your Computer".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before Working Inside Your Computer" After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
  2. Remove the memory module from the memory-module connector. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Align the notch on the NEW memory module  with the tab on the memory-module  connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Slide the memory module firmly into the connector at an angle and press the  memory module down until it clicks into place.
    • Slide the memory module firmly into the connector at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 56
