Saltar al contenido principal
Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement
Qué necesitas
  1. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement, Processor Fan and Heat Sink: paso 1, imagen 1 de 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 2, imagen 1 de 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 4, imagen 1 de 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 6, imagen 1 de 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
  8. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 8, imagen 1 de 1
    • Use a screwdriver to remove the two 2.3mm PH00 screws on the processor fan.
  9. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 9, imagen 1 de 1
    • Use a PH0 screwdriver to loosen the 4 captured screws on the heat sink assembly.
  10. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: paso 10, imagen 1 de 1
    • Remove the processor fan and heat sink assembly.
Conclusión
Una persona más ha completado esta guía.
Muhammad Erchid
Miembro Desde 10/09/18
1,069 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 279
