Saltar al contenido principal
Dell Inspiron 11 i3147 Camera Replacement
Qué necesitas
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: paso 2, imagen 1 de 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: paso 4, imagen 1 de 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: paso 6, imagen 1 de 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: paso 7, imagen 1 de 1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: paso 8, imagen 1 de 1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: paso 9, imagen 1 de 1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: paso 10, imagen 1 de 1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: paso 11, imagen 1 de 1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: paso 12, imagen 1 de 1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: paso 13, imagen 1 de 2 Dell Inspiron 11 i3147 Camera Replacement: paso 13, imagen 2 de 2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: paso 15, imagen 1 de 1
    • Use a plastic opening tool to take the camera module off the display.
Conclusión
Muhammad Erchid
Miembro Desde 10/09/18
1,069 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 223
