Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Display Hinges.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer. After working inside your computer, follow  the instructions in After working inside your computer. Peel the tapes and remove the antenna cables from the routing guide on the  hinge cover.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
  2. Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
    • Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
  3. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  4. Lift the display hinges off the display back-cover and antenna assembly. Lift the display hinges off the display back-cover and antenna assembly.
    • Lift the display hinges off the display back-cover and antenna assembly.
  5. Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
  6. Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
    • Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
  7. Route the antenna cables through the routing guide on the hinge cover and  secure it in place.
    • Route the antenna cables through the routing guide on the hinge cover and secure it in place.
Conclusión
Terrence15
Miembro Desde 18/12/17
71,146 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 71
