Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se requieren partes.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer. After working inside your computer, follow  the instructions in After working inside your computer.
  2. Lift the display-cable bracket  off the system board.
    • Lift the display-cable bracket off the system board.
  3. Peel off the tape to access the display cable.
    • Peel off the tape to access the display cable.
  4. Open the latch and disconnect the display cable. Open the latch and disconnect the display cable.
    • Open the latch and disconnect the display cable.
  5. Open the latch and disconnect the sensor-board cable from the I/O board. Open the latch and disconnect the sensor-board cable from the I/O board.
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Remove the antenna cable from the routing guide on the right speaker. Remove the antenna cable from the routing guide on the right speaker.
    • Remove the antenna cable from the routing guide on the right speaker.
  7. Open the latch and disconnect the I/O-board cable from the system board.
    • Open the latch and disconnect the I/O-board cable from the system board.
  8. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  9. Peel the tapes off the display hinges.
    • Peel the tapes off the display hinges.
  10. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  11. Place the computer face down on a  flat surface.
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  12. Lift the display assembly off the palm-rest and keyboard assembly. Lift the display assembly off the palm-rest and keyboard assembly.
    • Lift the display assembly off the palm-rest and keyboard assembly.
  13. Place the NEW display assembly on the palm-rest and keyboard assembly.
    • Place the NEW display assembly on the palm-rest and keyboard assembly.
  14. Align the screw holes on the display hinges with the screw holes on the palm-rest  and keyboard assembly.
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  15. Replace the screws that secure the display assembly to the palm-rest and  keyboard assembly.
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  16. Turn the computer over and close the display.
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  17. Route the antenna cable through its routing on the right speaker.
    • Route the antenna cable through its routing on the right speaker.
  18. Slide the sensor-board cable into its slot on the I/O board and press down the  latch to secure the cable.
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  19. Slide the display cable into its slot on the system board and press down the latch  to secure the cable.
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  20. Adhere the tape on the display cable.
    • Adhere the tape on the display cable.
  21. Align the screw hole on the display-cable bracket with the screw hole on the  system board.
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  22. Replace the screw that secures the display-cable bracket to the system board.
    • Replace the screw that secures the display-cable bracket to the system board.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 76
