Saltar al contenido principal
Dell Inspirion 15z-5523 Fan Replacement
Qué necesitas
  1. Dell Inspirion 15z-5523 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • First turn over your computer and remove all of the rubber stoppers on the back.
  2. Dell Inspirion 15z-5523 Fan Replacement: paso 2, imagen 1 de 1
    • Then remove all the screws that were under the rubber stoppers.
  3. Dell Inspirion 15z-5523 Fan Replacement: paso 3, imagen 1 de 1
    • Take the screw out of the back plate.
  4. Dell Inspirion 15z-5523 Fan Replacement: paso 4, imagen 1 de 1
    • Remove back plate by grabbing and lifting up.
  5. Dell Inspirion 15z-5523 Fan Replacement: paso 5, imagen 1 de 1
    • Remove CD port by pulling it straight out.
  6. Dell Inspirion 15z-5523 Fan Replacement: paso 6, imagen 1 de 1
    • Remove the keyboard.
  7. Dell Inspirion 15z-5523 Fan Replacement: paso 7, imagen 1 de 1
    • Take screw out of the surface below the keyboard and remove the top layer of the computer off of the base.
  8. Dell Inspirion 15z-5523 Fan Replacement: paso 8, imagen 1 de 1
    • Remove the battery by unscrewing the 5 screws and pull straight out.
  9. Dell Inspirion 15z-5523 Fan Replacement: paso 9, imagen 1 de 1
    • Remove the three screws from the hard drive and remove by pulling straight out.
  10. Dell Inspirion 15z-5523 Fan Replacement: paso 10, imagen 1 de 2 Dell Inspirion 15z-5523 Fan Replacement: paso 10, imagen 2 de 2
    • Unscrew motherboard and remove the two clips.
  11. Dell Inspirion 15z-5523 Fan Replacement: paso 11, imagen 1 de 2 Dell Inspirion 15z-5523 Fan Replacement: paso 11, imagen 2 de 2
    • Flip motherboard up, unscrew the three screws, and unclip the fan.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 839
