Saltar al contenido principal
Dell E193FPc Display Bezel Replacement
Qué necesitas
  1. Dell E193FPc Display Bezel Replacement, Stand: paso 1, imagen 1 de 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: paso 2, imagen 1 de 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: paso 3, imagen 1 de 2 Dell E193FPc Display Bezel Replacement, Display Bezel: paso 3, imagen 2 de 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: paso 4, imagen 1 de 2 Dell E193FPc Display Bezel Replacement: paso 4, imagen 2 de 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: paso 5, imagen 1 de 3 Dell E193FPc Display Bezel Replacement: paso 5, imagen 2 de 3 Dell E193FPc Display Bezel Replacement: paso 5, imagen 3 de 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 5-36, Amido Fall 2011 Miembro de Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 4,275
