Saltar al contenido principal
Dell Dimension 4600 Sound Card Replacement
Qué necesitas
  1. Dell Dimension 4600 Sound Card Replacement, Side Panel: paso 1, imagen 1 de 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Sound Card Replacement: paso 2, imagen 1 de 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Sound Card Replacement: paso 3, imagen 1 de 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Sound Card Replacement, Sound Card: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Very important at this point you connect your antistatic wrist strap to the chassis because the computer is no longer connected to ground at the power source. There is potential for static discharge which could destroy components.
  5. Dell Dimension 4600 Sound Card Replacement: paso 5, imagen 1 de 1
    • Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
  6. Dell Dimension 4600 Sound Card Replacement: paso 6, imagen 1 de 1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
  7. Dell Dimension 4600 Sound Card Replacement: paso 7, imagen 1 de 3 Dell Dimension 4600 Sound Card Replacement: paso 7, imagen 2 de 3 Dell Dimension 4600 Sound Card Replacement: paso 7, imagen 3 de 3
    • Locate and remove the white connector on the sound card by pulling on the black cable.
  8. Dell Dimension 4600 Sound Card Replacement: paso 8, imagen 1 de 2 Dell Dimension 4600 Sound Card Replacement: paso 8, imagen 2 de 2
    • Grasp the Sound Card and pull it up and out of it's slot.
Conclusión
6 personas más completaron esta guía.
Arvind
Miembro Desde 10/12/11
395 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-10, Regan Fall 2011 Miembro de Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
Miembros de 4
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 5,380
