Saltar al contenido principal
Dell DJ Disassembly
Qué necesitas
  1. Dell DJ Disassembly, Dell DJ Disassembly: paso 1, imagen 1 de 3 Dell DJ Disassembly, Dell DJ Disassembly: paso 1, imagen 2 de 3 Dell DJ Disassembly, Dell DJ Disassembly: paso 1, imagen 3 de 3
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  2. Dell DJ Disassembly: paso 2, imagen 1 de 3 Dell DJ Disassembly: paso 2, imagen 2 de 3 Dell DJ Disassembly: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
    • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
    • Be sure to keep the 4mm screws together and organized on the device magnet plate.
  3. Dell DJ Disassembly: paso 3, imagen 1 de 3 Dell DJ Disassembly: paso 3, imagen 2 de 3 Dell DJ Disassembly: paso 3, imagen 3 de 3
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  4. Dell DJ Disassembly: paso 4, imagen 1 de 3 Dell DJ Disassembly: paso 4, imagen 2 de 3 Dell DJ Disassembly: paso 4, imagen 3 de 3
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
Linea de Meta
Una persona más ha completado esta guía.
Un comentario
How did you get the logic board to slide past the scroll wheel ?
kf4qic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 614
