Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Speaker Replacement
Qué necesitas
  1. Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 2, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 2, imagen 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: paso 3, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 4, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 4, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 5, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 5, imagen 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 7, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 8, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: paso 8, imagen 2 de 2
    • Lift and remove the speakers from the device.
Conclusión
M Ali
Miembro Desde 11/03/21
313 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Pee Fall 2021 Miembro de Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
Miembros de 5
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 351
