Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Motherboard Replacement
Qué necesitas
  1. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 2, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 4, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 4, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 5, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 5, imagen 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: paso 6, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: paso 6, imagen 2 de 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 7, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift and remove the speakers from the device.
  9. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: paso 9, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: paso 9, imagen 3 de 3
    • Disconnect the keyboard cable.
  10. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 10, imagen 1 de 1
    • Disconnect the two input-output board cables from the motherboard.
  11. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 11, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 11, imagen 2 de 2
    • Disconnect the touchpad cable.
    • Disconnect the USB Type-C power cable.
  12. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 12, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 12, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  13. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  14. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 14, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 14, imagen 2 de 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  15. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 15, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 15, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 15, imagen 3 de 3
    • Remove the five 4 mm screws that secure the motherboard using a Phillips #1 screwdriver.
  16. Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 16, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: paso 16, imagen 2 de 2
    • Lift and remove the motherboard from the computer.
Conclusión
6 personas más completaron esta guía.
Muhammad Ali
Miembro Desde 09/02/21
352 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Pee Fall 2021 Miembro de Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Miembros
5 Guías creadas
Un comentario
Any idea how to use the USB repair shim? Dell's guide didn't help
Josie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 16
Ultimos 30 días: 46
Todo El Tiempo: 2,265
