Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Keyboard Replacement
Qué necesitas
  1. Dell Chromebook 3100 2-in-1 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Using a phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 2, imagen 1 de 1
    • Pry the back cover off the laptop.
  3. Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 3, imagen 1 de 1
    • Unplug the battery.
  4. Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 4, imagen 1 de 1
    • Slide the black clips towards the battery to release the ribbon. Lift the ribbon out and unplug the keyboard cable.
  5. Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 5, imagen 3 de 3
    • Turn the device over. Then, using a jimmy, firmly press between the keyboard and the laptop frame.
    • Repeat this process along both sides of the laptop and the bottom of the keyboard.
  6. Dell Chromebook 3100 2-in-1 Keyboard Replacement: paso 6, imagen 1 de 1
    • Once the three sides have been pried open, lift the keyboard slightly and pull towards you.
Conclusión
ot moya
Miembro Desde 11/09/23
481 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2023 Miembro de IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
Miembros de 3
3 Guías creadas
Un comentario
In case you were thinking about trying this without removing the bottom case, don't be like me. The center two screws on the bottom case, screw into the keyboard and the flex cable is not accessible from the under the keyboard. All steps in this guide are necessary. 🙃
Collin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 426
