Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Display Replacement
Qué necesitas
  1. Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Display Replacement: paso 2, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: paso 2, imagen 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Display Replacement, Battery: paso 3, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Display Replacement: paso 4, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: paso 4, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Display Replacement: paso 5, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: paso 5, imagen 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Display Replacement, Display: paso 6, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Display: paso 6, imagen 2 de 2
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  7. Dell Chromebook 3100 2-in-1 Display Replacement: paso 7, imagen 1 de 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  8. Dell Chromebook 3100 2-in-1 Display Replacement: paso 8, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: paso 8, imagen 2 de 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  9. Dell Chromebook 3100 2-in-1 Display Replacement: paso 9, imagen 1 de 1
    • Open the system to 180 degrees and place the computer on a flat surface, with the display hinges facing up.
  10. Dell Chromebook 3100 2-in-1 Display Replacement: paso 10, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: paso 10, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: paso 10, imagen 3 de 3
    • Remove the three (on both hinges) 5 mm display hinge bracket screws that secure the display assembly to the system using a Phillips #1 screwdriver.
  11. Dell Chromebook 3100 2-in-1 Display Replacement: paso 11, imagen 1 de 1
    • Remove the display assembly from the system.
  12. Dell Chromebook 3100 2-in-1 Display Replacement: paso 12, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: paso 12, imagen 2 de 2
    • Use the opening tool to open the display panel starting from the pry points located above the left and right hinges.
    • Work your way around, through the left and right side of the panel, and carefully flip the display panel over.
  13. Dell Chromebook 3100 2-in-1 Display Replacement: paso 13, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: paso 13, imagen 2 de 2
    • Peel back the adhesive tape securing the display cable on the back of the display panel and separate the display.
Conclusión
Una persona más ha completado esta guía.
M Ali
Miembro Desde 11/03/21
313 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Pee Fall 2021 Miembro de Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 33
Todo El Tiempo: 1,976
