Saltar al contenido principal
Introducción
Having trouble with broken or stick keys on your keyboard? This guide will provide you simple step-by-step instructions on replacing your keyboard for the Chromebook 13-7310.
  1. Remove the eleven 3mm Phillips #1 screws. Remove the eleven 3mm Phillips #1 screws.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Use a plastic opening tool to gently remove the back panel.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Remove the four 2mm screws on the sides of the battery.
    • Remove the four 2mm screws on the sides of the battery.
  5. To remove the battery, lift up on one side to get your fingers underneath and lift away.
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Gently pull to unplug fan connector.
    • Gently pull to unplug fan connector.
  7. Remove 4 screws securing heat sink. Remove 4 screws securing heat sink.
    • Remove 4 screws securing heat sink.
  8. Lift away heat sink.
    • Lift away heat sink.
  9. Remove the eight 2mm screws securing the motherboard in place.
    • Remove the eight 2mm screws securing the motherboard in place.
  10. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  11. Release cable for touch pad by pulling up on connector.
    • Release cable for touch pad by pulling up on connector.
  12. Gently remove the cable.
    • Gently remove the cable.
  13. Pull up on connector tab to release IO board cable.
    • Pull up on connector tab to release IO board cable.
  14. Pull up on connector tab to release keyboard cable. Pull up on connector tab to release keyboard cable.
    • Pull up on connector tab to release keyboard cable.
  15. Release the keyboard backlight cable.
    • Release the keyboard backlight cable.
  16. Release the keyboard cable. If taped to the motherboard, gently peel it off.
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  17. Release eDP cable.
    • Release eDP cable.
  18. Release dc-in cable.
    • Release dc-in cable.
  19. Gently lift up the motherboard to remove it.
    • Gently lift up the motherboard to remove it.
  20. Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly. Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  21. Using your fingernails, pull the cooling fan cables loose from the motherboard. We have the tweezers pictured to allow for a clear view of components.  DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
  22. Remove the single 2mm screw securing the IO board to the laptop.
    • Remove the single 2mm screw securing the IO board to the laptop.
  23. Pull up on the connector to release the IO board cable from the motherboard.
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  24. Remove the IO board.
    • Remove the IO board.
  25. Remove all screws.
    • Remove all screws.
    • All screws for the keyboard will have a "K" next to them.
  26. Gently lift up  the keyboard and remove.
    • Gently lift up the keyboard and remove.
    • This step does not require much force. If you have to use a lot of force to lift the keyboard, check to make sure you didn't miss a screw.
Conclusión
Una persona más ha completado esta guía.
Damon
Miembro Desde 01/11/18
181 Reputación
2 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 92
