Saltar al contenido principal
Dell Chromebook 13-7310 Battery Replacement
Qué necesitas
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 13-7310 Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: paso 5, imagen 1 de 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Conclusión
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,249
