Saltar al contenido principal
Dell Chromebook 11-3120 Battery Replacement
Qué necesitas
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: paso 1, imagen 1 de 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: paso 2, imagen 1 de 2 Dell Chromebook 11-3120 Battery Replacement: paso 2, imagen 2 de 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: paso 3, imagen 1 de 1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: paso 4, imagen 1 de 1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
Conclusión
Dalton D
Miembro Desde 12/08/17
2,534 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 375
